Enable Jumbo frames to increase the size of Ethernet frames supported
on the chassis.
On the Device
Physical View, select the device.
In the navigation pane, expand
Select
Chassis.
Select the
Chassis tab.
- In MTU size, select either 1950, 9600 or 1522.
Select
Apply.
